Having trouble removing lower
Having trouble removing lower unit from upper gear case. all bolts removed unit separates by dropping
about 1 inch.
Is this all that it will go untill shift rod is turned 90 degrees. unable to turn shaft 90 deg.
manual does not state how much lower unit should separate to disengage shift rod.
sterndrive is 1987 for 3lt
about 1 inch.
