D
Drake Dietz
Guest
"88 bayliner with a 5.0 chevy
"88 bayliner with a 5.0 chevy and OMC stern drive. Getting it ready for summer, first year I have had to wineterize and commision. Drain the lower unit to replace the oil. Was not cloudy or anything. But figured it should be done. Drained it, and wnet to fill using the next to lowest fill port. Took out the overflow plug on the side and commenced to fill. All done and wnet to put the overflow plug back in and there are no threads on the housing. Trying to attach a picture. It was screwed into something when I took it out. Only thing I can think is previous owner put a nut or helicoil in and it has now fallen into the lower unit. Any suggestions? I also had a lot of oil running out by the prop, so need to pull the lower unit to replace a seal for sure, but can not figure out what to do about the plug."
