I have recently bought a 1991 Four Winn’s Sundowner 225 with a King Cobra Daddy King outdrive. The only issue the previous owner mentioned was cracked blocked which I replaced. We took it out last weekend for the first time. The boat shifted great. As I started to throttle with my trim down it would take off for a few seconds and then the motor would over rev and lose bite. I tried it again but this time easing into throttle, same thing. I figured the prop was stripped. I could idel around just fine.
I went to load it up on the trailer, had to get on the throttle, not issues. We got home and I put the boat in gear and tried to turn the prop. The prop never slipped and I turned the engine over instead. Could this still be a prop or could it be something else.
The boat and prop is clean so I ruled out cavitation. I have a stainless steel 14.25x20 pitch prop. I’m not sure if it’s the right size either.
