OMC gasket Sealing Compound
turco555
Hi, I'm Adrian from Argentina and I have a OMC Sterndrive ElectricShift. I am replacing the seals and gaskets and for seal de gasket, the OMC Gasket Sealing Compound product is not sold in my country.
Neither are Mercury Perfect Seal 4, Loctite Aviation, or Permatex Aviation sold. The only solvent based sealant sold is "TiteSeal / NIelSeal Gasket Sealing Compound".
Other products (Not based solvent) for sale are rtv silicone sealant (loctite 5699) or anaerobic sealants (loctite 518).
Is titeSeal a suitable replacement for OMC? or it is better to use some other of those mentioned?.
thanks!! sorry for my English
TDS NineSeal/Tite Seal
FUNCTION AND APPLICATION: NIEL SEAL LIGHT WEIGHT is a flexible compound for use as a joint sealing compound, caulking compound, corrosive preventative, lubricant, threaded joint dressing, insulating material or filler with packing. Used on head and manifold gaskets of automotive and aircraft engines, water heater fittings gaskets, gas range valves and fitting, pipe threads on dry-cleaning solvent filters, railroad and truck air-brakes, fittings and lines, etc. For all metal-to-metal unions with any kind of gasket.
OUTSTANDING PROPERTIES: NIEL SEAL LIGHT WEIGHT is unaffected by water, oil, gasoline, glycerin, steam, gas vapor, exhaust fumes and most hard-to-hold liquids. Withstands extreme temperatures; will not harden, vibration-proof and easy to disassemble for repairs and adjustments. Prevents corrosion and seizing of metal parts. Expands and contracts with
temperature changes without affecting seal
USE DIRECTIONS: NIEL SEAL LIGHT WEIGHT will form seals at a temperature range of
20 to 250°F. Before applying, wipe surfaces dry and clean, then simply spread on. With gaskets: coat joint surfaces and spread evenly. Without gaskets: coat joint surfaces and embed small
thread or string as a binder. As a filler: apply as a bond between regular packing and metal
surfaces_ Do not use thinners.
Welcome, looks like a great product. Wish it was available here in the US.
Your English is better than mine, don't worry about that. I use Loctite 518 on machined surfaces that often require no gaskets and are subjected to fuel, vacuum, and pressure.....like aluminum crankcase sections.
