"I am exploring options for a
"I am exploring options for a boat I have.1970 uniflite 23' w/OMC(GM) v-8 and an OMC electric shift. I have water in the upper gear case as a minimum problem....the unit does push the boat just fine and the engine appears to be solid
1)will a Volvo 280 bolt up to that engine at the flywheel?
2)aside from the glass work to seal up the GIANT hole from the OMC, how much would be involved in doing this type of conversion assuming the volvo will bolt up.
3) do I just keep buying OMC electric shifts and build a parts supply.
Any insight for or against would be welcome
Thank you in advance."
