ShayneCastonguay
I have an 82' 50hp Johnson with the stock OMC control unit. My high idle lever has never worked, the lever, when pulled up, does not seem to grab anything and has no effect on the starting capabilities. It appears the cam that engages the throttle lever is bent and unusable. When I first encountered the problem, I simply isolated the throttle cable and made a separate throttle handle for speed control. Are there commercially available replacement cams? I would like to return to stock operation.
