Surfnsnowboard3
Good afternoon,
first post. I haven’t run my boat in 4 years. I used resources like this forum and YouTube to replace the spark plugs, spark plug wires, change lower unit gear lube, change oil and filter, change fuel filter and drain old gas fill with new gas. Boat started, which was a surprise. Some black smoke, which is gone now.
specs say idle rpm should be 550-650rpm. Lowest I can get at idle is about 1200 rpm. Is this ok? Also, with my Holley 2bbl carb idle screws each backed out 1.5 turns, my curb idle screw needs to be pretty tight to be at that 1200rpm range.
here is a short YouTube video I made to show what happens with idle screws all the way in (I think I read that may prove something is wrong with the carb). Is something wrong with the carb? I can do more videos or photos if needed.
https://youtu.be/zobWYnOP-q8
thx
thx
