Hi guys, Hey I recently changed plugs on my 1993 OMC Cobra 4.3 from NGK plugs to some AC delco platinum plugs ( 36 bucks for the set ) my brother recommended.
Well I put about 5 hours on the new plugs and noticed a miss not long after installing them.
I wasn't impressed with the new plugs anyway so I decided to change back to NGK.
When I pulled the plugs I found the #6 plug missing the electrode and the 90 degree tip was melted back about halfway.
Thought Great!... found my miss!
Put the new NGK plugs in and still have a miss! Checked compression and I only have 25lbs on the #6 cylinder.
I saved my old NGK plugs and looked at them...they all look ok.
Now I'm wondering if the electrode on the AC delco plug got stuck under a valve face?
I'm about the run that cylinder ) #6) up to TDC... blow some compressed ait in the plug hole and find out if it the intake or exhaust that's causing the problem.
Any other thought?
Thanks.
Chris.
Any other thought?
Thanks.
Chris.
