tylerlee001
Hey all, i just bought a 89 four winns with the 3.0l OMC. It ran great for the first 3 runs this year then a new problem popped up. Once the engine gets above 150 degrees (assuming F) it starts misfiring. I initially thought it was fuel, so i drained the tank empty and added fresh fuel with Sea Foam. I ran the engine, same issue. Runs great for 10-15 minutes,then starts misfiring/surging. You can feel the boat surge as it does it.
I replaced the fuel filter (dirty), clean the air intake (i have no idea how it ran). After i saw the filter, i check the plugs and sure enough the front 2 were black and the rear two were okay. replaced those with new and it does the same thing.
Is it running to lean when the engine heat builds? Do you think it needs to have the fuel turned up on the carb? It dosent produce and smoke or anything like that.
Im totally lost guys, I appreciate your help.
Tyler
Tyler
