Hello,
I have a 1974 Reinell 24'. I believe the engine is a 305 or 350 (v8). The boat is in desperate need of ball gears. The upper gear on the outdrive itself is pretty self explanatory, it has a nut that holds the ball gear on the shaft. The problem is the intermediate side. This side does not have a nut, Its a press on ball gear, Ive removed the cover to confirm. Ive been able to locate a number on the shaft itself but I cant find any new or used parts or information that correspond to the numbers 979983, It also has a logo imprinted on the shaft that looks like a "M" inside two squares. I would really like to find a replacement at a reasonable cost if possible or some suggestions on maybe replacing the entire outdrive, maybe that would be cheaper?
Also any information on the Reinell 24 "The Navy Yard" would be greatly appreciated too.
Thank you in advance!
