I have a tilt motor problem with my OMC 800 series stern drive. The motor will not lift up the out drive. I am not sure of the year of the out drive. It has a mechanical shift cable, if that will help Identifying the drive. The boat is a 1979 2000 Tierra *20' with 350 5.7 engine. The out drive is another used one that I put in. I have re- overhaul the tilt assembly and cleaned/greased *pivot arms. The tilt motor seem to not have the power to raise the drive. I did hook up a 12v power drill to it snd seems to work good up and down. The tilt motor is a new one (wps model 82-6850). Could motor just not have enough power? Could it be wrong one? I also checked ground and added new solenoid. Have 12.7 volts to tilt motor.
Would you have any suggestions on why this will not work?
Thanks for any info
Mike
[email protected]
Thanks for any info
Mike
[email protected]
