I have a 460 OMC that the impeller shaft ( 0984264 BRP # ) is too short , ie : pressed into U joint carrier , and the impeller is coming off shaft only under high RPM conditions.
To get a shaft that is the correct length to hold the impeller in place , what BRP parts would I need to buy ? Is there a way to pull the incorrect length shaft back out of whatever it is press fit into ? Would it be advisable to replace the entire u-Joint and water pump shaft ?
Also , I have gear lube getting past the seals and into the water passages in the impeller area, any ideas what orings/ gaskets or whatever would fix this issue?
