"ok, so I had a slight "po
"ok, so I had a slight "popping" sound through the carb, so I changed, cap/rotor and fuel filter. Basically ran the same, maybe slight improvement(less popping). Then things went wrong... saturday I took the boat out, was normal running. anchored for a bit, then I had to do an emergency start and go - FAST (drowning victim nearby). After I got them out of the water, went to start the boat and didnt want to go.(thank god was after I got them). When it did finally start its really rough, like running with a few cyclinders down. the motor shakes violently if you try and idle it, has no power.
I was told leaking manifolds/risers? I been reading posts here and learned of this interrupt switch - could I have done something with the quick start and go?
any suggestions?"
any suggestions?"
