vicperdido
"Need help. I was Idling along
"Need help. I was Idling along in gear with my 1989 5.7 omc stern drive. It went dead. I tried to restart it and the engine would not turn over. you could hear the starter clicking but would not turn engine. All manifolds and risers are less than a year old. Thought it might have ingested water so I pulled all of my plugs to check the engine and w/o the plugs it still would not turn over. I tried to turn it over with a long ratchet on the crank shaft and it wouldnt budge. Oil pressure and temp were good when it quit running. Recent oil change,and recent stern drive water pump. I was told that it may be the outdrive that is locked up and not the engine. Prop spins freely in nuetral and no grinding or other noises. Of course would not turn in gear. Any thoughts of what it might be and how to check it? Only way I know of checking my out drive is to pull it to see if that is it."
