I purchased a 1989 19’ Sea Swirl Sierra Classic with an OMC 4.3 liter 2 barrel Rochester 2cg carburetor in non-running condition. The previous owner purchased a rebuilt carburetor and could not get the motor running. After I purchased the boat I installed a new ring gear on the flywheel, new OEM starter, new OEM spark plugs all new fuel (no ethanol), fuel lines, all new fluids, new water pump on the drive and Pertronix electronic ignition. I still could not get the motor running so I purchased a remanufactured carburetor from I-5 Components and installed it on the motor. I got the motor running and it sounds great on earmuffs. It will idle at 600 rpm and rev up to 4500 and does not miss a lick. I put it in the water and the motor runs bad above 3000 rpm and has a sporadic hard knock. I put the boat back on the trailer and looked at the spark plugs and they are very black with dry carbon. I bought another set of plugs, a timing light and vacuum gauge to try and diagnose the issue. I found that the vacuum would fluctuate between 18 and 20. The timing is set at 28 degrees at 600 rpm. I have read that it should be at 6 to 8 degrees at 600 rpm. If I try and retard the distributor it will run bad and the engine shuts down. I adjusted the carb metering screws to 1.5 turns out and still have the same issue. I checked the TDC on the #1 cylinder and the timing mark is set properly with the rotor pointing toward the #1 cylinder and double checked the new Mallory marine 8mm spark plug wires were in the correct firing order starting with the #1 wire above the rotor and then 6-5-4-3-2 in a clockwise order. Again the engine ran great on earmuffs and terrible in the water above 3000 rpm. I pulled the plugs and found them very black again. I am beginning to think that the jets are incorrect. What size jets should be installed on a stock motor and will smaller jets allow me to retard the timing to 6 degrees? What else should I look for in the carburetor such-as power valve size once it is apart? Any help or ideas would be very much appreciated.
