Marine gasser ignition timing, advance curve and TA (total advance) are too important to risk not having correct.
I'd recommend that you take the distributor to a shop who owns an "Old School" Sun, or other, Distributor Machine (and one who has a Technician capable of operating it), and have it correctly set up.
This is done dynamically, rate of spring tension, etc, will all be adjusted, and will be very close to Dead-On when done!
You will need to provide the correct OEM curve for them. DO NOT use an automotive curve!
NOTE: Is this by chance one of the odd firing angle gm v-6 engines????? (I don't know enough as to which models used this.)
Seems that there are one or two of these smaller GM V-6's that DO NOT fire in equal divisions of crank angles.
IOW, there is a division that is not separated by an equal 120* of crank rotation (60* of distributor angle).
If so, this distributor is "Index" sensitive when re-installing.
BTW, the cam weights would have moved in order to have given your engine any Ignition Advance.
It would not have worked otherwise..... and you would have had ZERO power!
Likewise if this is index sensitive.
