I replaced the water pump, and some upper gearcase seals, on my OMC Stringer 400 1983 model. The case vaccume tested great and held vaccume for 3 hours without the guage moving. One trip around the lake and when I removed the 'dip stick' from the upper drive a foamy mixture of water and oil pushed the dipstick out of the hole.
I did something bad wrong and am about to start from scracth and do it all over again.
Before I start I have three concerns (to start with)
1) Above the water pump there are 2 seals (981268) that go back to back, in the bearing housing. The old seals I removed were pressed in flush with the bearing housing. When I put the new ones in I made a tool and pressed them in till they hit the 'lip' deeper in the bearing housing. Which is correct?
2) I did not put permatex around the outer perimiter of the impeller housing. (I did do the bolt threads and heads, and both edges of the impeller cover plate) I will include the housing this time.
3) The large rubber 'O' ring that comes with the kit shows being installed between the swivel housing (910239) and the bearing housing (910240), around the outside perimiter of the impeller housing. Is this correct?
If anyone else has experienced similar results with this project I would appreciate hearing what solutions were found.
I hate it when this happens.
