Unlucky omc 1978
Hi.
I'm desperate for advice. I recently bought an old daycruizer with an omc 120 hp engine (1978). I'm guessing that means I have a sterndrive 400? It looks like it from pictures I've seen online at least.
When I bought the boat, and drove it home, everything worked great. The next day, everything worked just fine as well. The third day, I desided to bring the wife and kids along for a day on the fjord. We put out from our dock and brought the boat nice and easy up to a good speed. And then the engine suddenly revved up, and had no power forward. I immediately killed the engine, raised the drive out of the water to check if the propellar had fallen off or something. But that was still there. I then lowered the drive again and attempted to start the engine and put it in gear. Both forward and reverse was tried, but no go. We luckily got towed back to our dock. But now I'm at a loss, since I have NO knowledge about engines and drives.
What can this be? I've tried putting it in gear with the engine off, to feel for resistance when turning the prop manually. There is some resistance both forward and reverse.
When this happened there was no foul noise or anything to indicate anything was wrong. It just lost power.
I'm Norwegian, so I appologize for any misspellings that may have occured in the making of this desperate post on your forum. I hope someone has experience with similar cases and can guide me along.
Thank you.
Thank you.
