So I made the error of forgetting the drain plug in the hull, water froze under the engine and pushed the oil pan into the crankshaft...
I have to pull the pan off and either pound it out, but I'd rather replace it as it is dimpled from the connecting rod bolts. Model number is 990239M, and I believe it is a GM 250CID 4.1L if I'm not mistaken, but can't find an oil pan for either engine for some reason. Thought maybe the pro's would have a solution! Also, if the automotive pan will fit, but the drain plug is in a different location, I can handle that!
