Hi,
Had a problem with no spark, so I bought a new CDI ignition module. It is a perfect replica. However, after replacing it, I still have no spark at any of the 4 spark plugs. I believe that the stator is good as the yellow stator windings ohm out properly. However, there are two other brown wires off the stator that measure open. I also tested the kill switch wire and it tested ok. I don't have the manual for this year engine and can't identify their function. Does anyone out there know or have a suggestion?
Thank you!
Thank you!
