A
alex stanton
Guest
"I have a 1979 OMC 120 engine
"I have a 1979 OMC 120 engine which (with the help of everyone here) I came to the conclusion that it is siezed up. The boat has sat for over 10 years, and about 5 years ago someone pulled the spark plugs and let it sit outside.
The rest of the boat cleaned up very nice (new carpet and seats and we're back in business), I'm told the mechanical OMC 400 Sterndrives are pretty tough, and I'd like to get her in the water.
What are my options as far as engine replacement? I'm fairly mechanical, don't mind rebuilding an engine if I have to.
So I've been doing some research and it looks like the GM 2.5 was used in a lot of cars. Will ANY GM 2.5 or 3.0 4 cylinder inline bolt up to the OMC Sterndrive bell housing? If so I found a rebuildable GM 2.5 that came out of a FWD vehicle from the early 80's (Pontiac I think). Does the FWD factor make a difference?
Also, is there a Mercruiser branded engine that is a direct replacement for the OMC 120? A lot of people are selling mercruiser 140 GM engines and I am under the impression that these are the same as the OMC 120. I believe the water pump for my OMC is in the Outdrive... if I were to buy an automotive longblock would I be able to run it in a marine application?
Thanks all for your help, the boat isn't worth a lot, but it sure would be nice if I could find something economical to get it in the water at least for this year."
