I have a 17' open bow Renken w120/IO w/400 out drive.It is giving me a bad time.
sometimes it won't get up on plane and it will eventually heat up.other times it will get right up
on plane and run up to3800 rpm,and it will be fine UNLESS I try to open it up.When I do this it will not rev op any higher but it will get hot.If I pull the throttle back to where it is running at 3800 it will again run fine.
1-could this be water in the fuel ?
2-be wrong prop size?
3-HELP ME
3-HELP ME
