"ran slow for a while then spit and sputtered and took off" likely indicates you have something getting into the fuel passages of the carb.
It clears out and the engine runs good. Then it "dirts out" again. The fact that you don't have a fuel filter could have something to do with that.
These outboards came with a small, inline fuel filter between the fuel pump and the carb. But, this old girl has been around for a while and someone probably thought she didn't need it at some point. I would plumb one back in as well as at least think about installing another in the fuel supply hose from the tank just as an added measure of "security".
They do not have to be anything fancy. Just some inexpensive. in line. fine screen filters that you can pick up at any lawn mower repair shop.
While you have the lines off, pump the bulb and squirt some of your fuel into a glass jar and let it sit for a time. Look at it closely to see if you may have any debris in it. The old metal tanks that came with these engines are all starting to break down internally and you may want to go plastic if your fuel is being contaminated by your tank.
Sorry to say it but you will probably need to clean the carb again if dirt has been the problem.
There is a chance the fuel pump is weak and perhaps pumping erratically. Unlikely but possible.
Also, another thing that would make an outboard "sputter for a while and then take off" might be;
Leaking intake assembly where, after the engine warms up, the metal expands and sort of seals up the leak automatically. This happens sometimes when a guy has been taking the carb off and putting it back again with the old gaskets when he's trying to sort out running issues. New gaskets are always advisable but we all know not always possible. Again, pretty unlikely but it could happen.
Who knows? Your new plugs might do the trick so try them first. These do run on only one cylinder and be down on power as you describe. But if that doesn't do the trick, consider some of my points.
There's some stuff to look at,
I hope you figure it out.
