sandkicker
Outstanding Contributor
Ok... I got tired of fiddling (several bouts with seafoam) with the engine and sent it to my mechanic, where is sat for several weeks (OK, its peak "season") and was returned with a $100 repair bill. I got it back and it ran Ok for a few mins and then stopped. Mechanic won't even look at it until November... It appears to be a float level/valve problem, as when I pump the bulb until its hard and then open the carb drain, a small amount of gas flows out and then stops but the bulb is still hard and won't pump further. Removing the fuel line from the carb allows gas to be pumped thru the system up to the point where the hose attaches to the carb. I replaced the fuel line and then pumped it up and then took the carb off and left the fuel line on and removed the bowl. Very little gas in the bowl. I then pumped the bulb and some gas squirted out and then stopped with bulb remaining hard (bowl removed, carb in normal orientatin!!!).
Since I was charged for a new float needle, I am assuming that the float level/drop settings are wrong. I know this info is in the OEM Honda shop manual, however, I moved recently and can't find my copy of the manual.
Anyone know what the level/drop measurements are supposed to be for this engine?
Its a 150 series, 7.5 HP...
TIA.....
TIA.....
