"Hi, I have an 'old" H
"Hi, I have an 'old" Honda, with the blue and white case cover, and I just got it running after it sat for (?) years. I replaced coil and wires, plugs, fuel pump, and drained 'lower end" and refilled, and did same for upper end...now, it will run strong on top end, but will not idle, and I cleaned and reset carb...so I am wondering...is there toooo much "play" in the rings and Valves such that there is not enough "suck" at low speed for fuel..because of age of motor,and I should rebuild it, or is there....because "you" are a vast "universe" of knowledge...something I overlooked? Cheers
Syd"
Syd"
