"I have a question about fuel.
I am in the process of winterizations for my boat like many others are. Guy, I have your check list and that has been helpful.
Currently I have an almost full tank of gas in the boat now, but probably some of that gas is from the end of last year too. I always use gas stabilizer, I am not sure I should let this tank set through the winter? Any thoughts? I am thinking I should pump the gas out ( I know that will be a pain!) and fill tank with fresher gas.
Also, I have not normally not fogged the engine, but would, of course, drain the water. I store the boat in a garage under the house and the temp is usually in the 60's, and I usually pull the boat out a few times a winter and start it and let it run for half an hour or so (on muffs), and then drain the water again. Does anyone know of any problems that might cause too?
thanks,
Jasson."
thanks,
Jasson."
