arlenmcgee
Hello, Need some guidance.
Details
Im 63 yrs old
can work on these motors
bought a 1971 25hp outboard, recoil start short shaft model 25102
have ordered a manual, fuel pump, condenser, points, impeller etc from
you guys and am waiting on delivery.
previous owner said new impeller last year
took out last week, started 3rd pull, and ran at top rpm for 3miles with no problems
then at top end engine began throttling down to about 1/4 throttle and would not increase.
I throttled back to idle for about 30 seconds with a mild rough idle then idle smoothed
and gave full throttle and ran great for about 500yds 3-4 minutes or so and then did the
same thing. this repeated for about 5 repeats and I then went to dock.
Bought new 6 gal fuel tank, fuel lines bulb and connectors, put fuel, carb cleaner in new tank
and new fuel. Ran yesterday, not really much difference and ran boat 7-8 miles (1 hour)
Plenty of water is coming from the exhaust port, and finger on cylinder housing, seems to indicate
that water is cooling the cylinders adequately. Have not checked compression yet, will do that today later.
Looking for best guess direction to go in.
thank you
Details
Im 63 yrs old
thank you
