88_grady_white
"I have an 87 Merc 175hp that
"I have an 87 Merc 175hp that runs great (still). That's not the strange part.
I have been dealing with a heat issue in this motor that is driving me nuts. From just off idle to about 3000 RPm's it runs hot (very hot) and it never used to. This would lead me to believe that the poppet valve is not functioning correctly.
Before you start thinking, new in the motor;
Water pump(s) (pulled a couple of times to make sure everything was correct, and it definately is)
Thermostats
Poppet valve
New old stock heads (very clean)
Power packs and stator
All water passages checked to ensure propper flow
Water pisses out of the telltale like me when I was 20!
Any other suggestions on this would be appreciated!
Here is the strange part (finally). The poppet valve does not appear to have anywhere to dump the extra water? What I mean is, the newer models have another passage next to the poppet plate where the water diverts to, this one just has a plug valve held in place by the spring and plate - when the poppet lifts where the hell is the water supposed to go? I do have a sand plug in the motor that I could pop out and install the newer type poppet setup (after drilling and tapping a couple holes around this passage). But as I said before, the first six years I owned this motor it ran in the cold no matter what. GO FIGURE."
Thermostats
Poppet valve
