kghost
Silver Medal Contributor
Ok so it is my turn for some advice,
My friends boat, 1996 ski boat 20 ft (fresh water lake, no salt water)
rebiult motor installed by me and carb rebiult by me in 2001, No issues for the last 10 years.
Last week (been in use for the last month) was using boat and started hearing a wierd noise, sounded like pinging as he descibed.
I advised to stop using and do some diagnostics
I had him take the spark plugs out, change the oil as he said there was some water in the oil and crank the engine over and give me the information on what the results were, ( I was away last weekend so could not be there myself).
(these guys have very limited mechanical skills)
They did as i asked and the resultes were,
Water from # 1,3,5 cyclinders and 6. Oil was normal amount for the most part so water was a result of what ever the issue is so I ma confident it is not a cracked block.
I was there yesterday and I confirmed water comming out of 1,3,5 and 6
3 is the cyclinder with the most water shooting out of it.
I was attempting to do a compression check but developed a secondary issue with the starter I believe as the starter is 15 years old (rebiult unit installed by me in the late '90's) so I could not get enough cranking speed to get accurate compression.
Boat has been pulled and brought to my house for furrther diagnostics on cranking issue and to identify and hopefully repair the wate issue.
So my question to anyone would be
So what are your oppinions as to why water would be comming out of cylinder 6,
If blown head gasket I could see one bank having water, but the fact the other bank has one is troubling.
Could this be a intake manifold issue???
Maybe both exhaust manifolds/elbows crapped out?? (this set up has only the water feeding from the bottom of the manifold up and thru the elbow. NO water directly to the elbow).
Ok I would appriciate any suggestions.........before I tear into this beast........
