Oil warning module on 1994 125 Mariner
J
Jesse Flory
Guest
" The oil warning module is be
" The oil warning module is behind the oil resevior on the outboard and I will need to remove the tank to get to it, correct? Thank You "
SORRY BUT THE MODULE IS NOT B
SORRY BUT THE MODULE IS NOT BEHIND THE OIL TANK. IT IS A SMALL SQUARE BLACK PLASTIC BOX HELD ON WITH TWO 5/16 HEAD BOLTS. IT IS LOCATED ON THE BOTTOM STARBOARD SIDE OF THE BLOCK BELOW THE ELECTRIC STARTER. IF YOU NEED ONE PLEASE LET ME KNOW. GOOD LUCK.
" Thanks, found it. How much d
" Thanks, found it. How much does one of these run? "
THERE ARE 2 DIFFERENT MODULES
THERE ARE 2 DIFFERENT MODULES USED. ONE IS $44.75 CDN AND THE OTHER IS $85.00 CDN. I WOULD NEED YOUR SERIAL # TO SUPPLY THE CORRECT PART. PLEASE LET ME KNOW. THANKS
