Oil to fuel ratio
geoff
" If the oil to fuel mixture w
" If the oil to fuel mixture was way off putting way too much oil mix in, would that cause small oil slick in the water and make the motor hard to fire after long runs? "
" Also, My 1989 Johnson 150 ca
" Also, My 1989 Johnson 150 came with an oil tank, but someone told me to just add oil in with the fuel at 16:1. That just seems like way too much to me. Maybe 50:1 like Marci said? If the oil tank works, do I just fill it or how does it work? any Ideas? thanks..... "
Your best bet is to buy a man
Your best bet is to buy a manual or see a dealer.You are doing far too much guess work and that will cost you a lot of money sooner or later.
" if you use johnson oil run 1
" if you use johnson oil run 100 : 1 which is a syn. oil , if your using petrolium 42 : 1 if it older 50 : 1 if newer "
