Silverton 34C, heavy boat, needs all of big block torque.
I recently replaced the OEM engines from this '89 boat, with rebuilds from Promar.
A shout out to them, very happy with the results and the professional build. (Disclaimer: not affiliated in any way) I had originally planned on doing a valve job and related, but after tearing the top of one apart, I realized they were simply worn out. I had Promar install Comp Cams torquer cams, and replaced the OEM quadrajets/manifolds with Edelbrock 1409 marine carbs and Performer manifolds. Usually the BBCs come with 750 cfm Quads, these Edelbrocks are 600cfm. After talking to the folks there, their consensus was that 600 was more than enough to get to 5000rpm, more than I will ever run. This was a fortuitous decision, as the gas usage is significantly less than it was stock. According to my fuel sensors/Garmin network, I am burning gas at the rate of 1.3mpg at 3100 rpm, 20kts. Unless you are racing or need over 5000rpm, don't let anyone tell you need those gas gulping 750s. I'm showing usage of around 3mpg at trolling speed, 1200 rpm/6kts.
Now to the problem: I am using Amsoil 15-40 HD Syn. Diesel and Marine oil. Talked to the tech dept. there and this what they recommended. My water temps are rock steady at 180, both engines. Oil pressure 60lbs idle, 50 when warmed up. HOwever when I go to over 3000 to get somewhere, the oil pressure drops to 40 lbs one engine, 45 the other. This indicated to me the oil temps are higher than they should be. This is a closed cooling system, and I have a feeling the stock heat exchanger is inadequate. Any suggestions on a different/better oil cooler? Also some advice where would be a good place to install temp sensors on the BBC MKIV?
Thanks for any input.
