Oil Tank Leak 1994 115 HP MercuryYamaha 4 Cylinder
bobbyc
Advanced Contributor
"I have a 1994 115 Mercury whi
"I have a 1994 115 Mercury which leaks oil from the lid of the plastic VRO tank. The leak occurs whenever the motor is tilted. I have replaced the gasket and tryed to keep the tank less than full but to no avail. I asked the local dealer about ordering a new one and he tells me they "all leak". My question is for anyone who has experience with this problem on this motor. The tank is $80.00 and it seems the cap and related parts are sold separately. The tank looks fine, the cap fits tightly and the only thing I can guess is that the gasket design is less than perfect. My next step will be to make my own thicker gasket or to try using two gaskets. I bought this motor last year and with the help of several people on this site, I rebuilt the carbs, sychronized the linkage, adjusted the timing, idle and oil pump. The engine actually runs quite well and even the 2 to 4 transition is not really too bad. This oil leak problem is annoying and I would like to hear from anyone who has corrected the problem.
Revise your Message
Subject:
Post: -Color- Black Red Green Blue Yellow Purple Orange Cyan Gray White -Font- Arial Courier Symbol Times Verdana -Size- Smallest (-2) Small (-1) Normal Large (+1) Largest (+2)
I have a 1994 115 Mercury which leaks oil from the lid of the plastic VRO tank. The leak occurs whenever the motor is tilted. I have replaced the gasket and tryed to keep the tank less than full but to no avail. I asked the local dealer about ordering a new one and he tells me they "all leak". My question is for anyone who has experience with this problem on this motor. The tank is $80.00 and it seems the cap and related parts are sold separately. The tank looks fine, the cap fits tightly and the only thing I can guess is that the gasket design is less than perfect. I bought this motor last year and with the help of several people on this site, I rebuilt the carbs, sychronized the linkage, adjusted the timing, idle and oil pump. The engine actually runs quite well and even the 2 to 4 transition is not really too bad. This oil leak problem is annoying and I would like to hear from anyone who has corrected the problem.
Oil Tank
