Oil Tank Hookup on 150 Evinrude
hlj
I'm swapping a 1998 Evinru
I'm swapping a 1998 Evinrude 150 hp Fitch for a Evinrude 150 Ocean Pro Carbed Engine. The Oil tank used with the Fitch has a supply line with primer bulb and another hose (I suppose vent hose) that was hooked up inside the cowling. There is no place to hookup the hose on the carbed engine. What should I do with it??
Just block it at the tank end.
Just block it at the tank end. That hose (5/16) was used as oil-return from engine to tank. The thinner one i the suction hose.
