Oil sock question
gittyup
"89,johnson,60 horse,vro, repl
"89,johnson,60 horse,vro, replaced vro,thermastat,water pump.alarm goes off at full throttle,but runs great at not quite at full throttle,sock in oil res. looks good but I cant tell for sure.looked on web for a new sock & cant seem to find anybody that sells them.. thanks for any help.."
"shop.evinrude.com
what exact
"shop.evinrude.com
what exactly did u do w/vro...did u replace pulse fitting?...did u go by the factory service manual procedures for replacing vro,did u run oil consumption tests and both low and high speed to verify oil consumption?,replace oil hose and bulb?...bleed oil line?
Remember,..your whole powerhead,depends on that system,working as designed...in my opinion,the vro pumps are not -Plug-N-Play,,,unless,....u r a gambler.....if u just inst a new vro,..u did about 30% of the job that is needed.
You could have a HS overheat prob....(bad water imp)"
"I just installed a whole new
"I just installed a whole new pump, its is burning oil but I dont know how much..thanks for the info.I'll be calling my mech. and make an app.thanks again"
