tboltmike
"My '75 115 has just had t
"My '75 115 has just had the lower unit resealed, drive, propeller, shift shafts, new water pump by the long time OMC dealer. Passed the vacuum and pressure test.
I ran it one the hose a couple of times and found no water in the oil, but the level was below the vent plug. Added oil on two occasions, maybe 20 cc's. Ran in the bayou for about 30 minutes to confirm the repair. Found the oil clean but again low about 20 cc's.
A couple of days later found a very thin film of oil coming from the adapter plate down the fwd port side of the exhaust housing down to the cavitation plate. The engine had been sitting near upright but turn a little to the right. I seems to have collected at the housing to lower unit joint, but can't tell of coming from the top of the lower unit too.
I have never seen this before. I ran on the hose to see if I could see any leaks, but no.
Can imagine why oil would be leaking from the power head area. Oh, too, the carbs were run near dry.
Any ideas are appreciated."
