I've got the correct distributor in and have just about buttoned up both engines. I got the pumps primed, but had a question about how much force it should take. I used a priming rod on a drill to about 30PSI until oil showed at each rocker. The thing is I damn near burnt up my drill. It smoked for a couple minutes.
Thoughts? Should I have used the heavy duty low speed drill?
Other than that, I think I'm ready to go. Need to close up the cooling system and the ignition, dump in the break in additive then prime up the fuel system.
Any other checks you'd recommend before the first run?
