ableseaman
"Hi, Took my 125b out on the l
"Hi, Took my 125b out on the lake and noticed zero or slight show of oil pressure. Ran at low speed ,high speed ,no movement of guage.
Engine did not make unusual noise or overheat.
Aborted trip and jumped wire from sender terminal to ground, showed full oil pressure with ignition on. Removed sender and checked resistance across terminal to ground section. showed 280 (approx.) ohms. My question. Bad sender or (horrible thought) failed oil pump.
Appreciate advice.
Thanks, Ableseaman"
Appreciate advice.
Thanks, Ableseaman"
