Oil prime VRO 2
reel_magic_3
"I have 1999 225 johnson, with
"I have 1999 225 johnson, with VRO 2 system. I was doing a low oil tank check, and the book told me to remove the four torx screws and lift sending unit up until alarm/led sounded. Engine was not running. Question is have I broken the oil prime and will there be air in the vro system now or will there be no effect on the system? thanks"
"as long as oil hose was not d
"as long as oil hose was not disc,..u should be fine.....u r doing a good thing,for ck'ing your sys....empty oil tank,and clean and replace filter too."
