measure with a mechanical gauge ($20 at auto parts store) to see what the engine really is. If you take the wire off sending unit and ground it gauge if good should peg. With wire off sender I think gauge should move if constantly pegged.I need help troubleshooting high oil pressure on 2001 Mercruser oil pressure. Pressure reads constant 80+. I thought it might be the sending unit but it's not. What's next?
Thanks for all the replies. I attached a manual guage and pressure reads 45 to 50 psi. So I'm thinking maybe it's just the gauge on the dash?measure with a mechanical gauge ($20 at auto parts store) to see what the engine really is. If you take the wire off sending unit and ground it gauge if good should peg. With wire off sender I think gauge should move if constantly pegged.
If mechanical gauge is reading the same 80 psi all the time would think relief spring is stuck, but can cross that bridge if you come to it.
yes start the engine remove wire from oil pressure sender and ground against the block gauge should pegThanks for all the replies. I attached a manual guage and pressure reads 45 to 50 psi. So I'm thinking maybe it's just the gauge on the dash?
2000 Mercruser 5.7
New oil and filter
Been reading high for a while
I'm really a novice so I'm not real sure how to do what you suggest, "If you take the wire off sending unit and ground it gauge if good should peg. With wire off sender I think gauge should move if constantly pegged."
Do I just hold a wire from end that I take off sending unit and ground to the engine or where?
Guage reads zero when engine is not running but pegs when running
if 80 PSI on the gauge is full scale, then it is 'pegged'...in that case, its likely the wire between the sending unit and the gauge is shorted to ground somewhere along its length...
Ohmed detached sending unit. It was over 240ohms Actually I put a new one on also because I didn't know how to check it before. I used mechanical gauge directly in port for sending unit and pressure was 45 to 50 psi when I started engine so pressure seems good.How do you know its not the sending unit?
If its not the sender and if a mechanical gauge reads corretly then it must be gauge is bad
I'll try this test. I also already ordered another gauge for dash just in case that's the problem. If not I can return it.yes start the engine remove wire from oil pressure sender and ground against the block gauge should peg
As Kghost pointed out this is only a down and dirty test to make sure the gauge is moving through its range.I'll try this test. I also already ordered another gauge for dash just in case that's the problem. If not I can return it.
