missnancy
Hi all,
looking for advice as I go along. I had an earlier post on oil pressure and temp, the temp is cured and now I have to deal with the oil pressure. A quick history, I did a rebuild on my 350 pacer/crusader engine. She starts right up and sounds great. Oil pressure when I start is at 50 lb's. when she gets to temp which is around 165 degrees than the oil pressure at idle drop's to next to non existent and at 2000 to 2500 rpm's it is around 40 to 45 lb's. I have pulled the boat out and now am getting ready for the wonderful task of yanking the motor out again. I am running a straight 40 weight in her as someone had suggested and that helpd a bit on the higher rpm's but not on the lower. My kid brother who is a GM tech is leaning towards bearings and others have suggested a stuck relief valve, bad pump and so on. What do you all think? I am open to any ideas you might have.
