pascalmekkelholt
I have a oil pressure switch that has 2 metal slevees on it. 1 says NO on it and the other is C on it? Which one is for the fuel pump.
Okay much thanks for the info. Is it possible that if you connect it wrong. It will give pressur to the fuel pump? And it will flood the carburator and engine whit fuel??C = common
NO = Normally open.
NO would go to pump
C would be power +12Volts
When pressure is at or above 5 PSI the switch will close supplying power to fuel pump.
Nope,....Okay much thanks for the info. Is it possible that if you connect it wrong. It will give pressur to the fuel pump? And it will flood the carburator and engine whit fuel??
I dont have a multimeter, the New sensor has wires on it both are purple. And dont say which is C and NO strange.If you have a multimeter, check that there is no continuity between the C and NO contacts when the engine is off qnd wires to switch disconnected.
Not sure what you mean by new oil sensor and sensor switch?Hmm okay strange i find since whe pluggen a New oil sensor and sensor switch it.just floods the carburator and engine fuel whit fuel, and all the bougies are wet of fuel
