Oil pressure sendergone again
D
Dan Scheg
Guest
I have 1999 four winns with 5.
I have 1999 four winns with 5.0 Gi volvo penta---when warm the oil pressure drops to red zone and "beeps"---same happened few yrs ago and oil sender replaced and solved problem for few yrs--now doing same- sender bad again? Stops "beeping" if up rpm to about 1000.
common problem? engine sounds fine and runs fine otherwise----thanks--
"Let's HOPE that's wha
"Let's HOPE that's what it is! If so, it might be vibrating itself to death due to its mounting arrangement. Is it screwed hard into the block, or mounted in a panel and tied to the motor via a hose?
Jeff"
