"Twin 454s (1998). Thi
"Twin 454s (1998). This weekend I was on the bay (Chesapeake) on a good run pulling into an anchorage when the port engine oil pressure dropped off the scale (pegged below zero;like a short). The low oil pressure alarm did not sound which lead me to believe it was a false reading.
I do not believe it is the gauge (connected stbd engine sender wire and read fine). After taking calculated risks (monitoring engine temp, oil cooler input temp, oil cooler output temp, sounds) we took off the next morning. After hitting a small wake, the meter started to read again. Though it varied wildly from its normal reading it continued to read. Could the sender unit be going south and is the actual alarm tied to a different sensor?
David"
David"
