wh1278
I have read several older posts, but I still have this question. Both my 440's after rebuilds read higher than anticipated oil pressure. I first had them pegged at 80 psi, and discovered they rebuild guy put on single station senders on my dual station boat. I replaced the senders, but am still getting somewhere between 65 and 80 (hard to read on guage). Not pegged, but high at all RPMs. I've changed the oil, and had a manual check done to validate the gauges. Now the question. Do I pursue the replacement of a spring in the oil pressure relief value (if so where do I find one), or should I consider one of these adjustable gizmos on 440source.com: http://store.440source.com/Adjustable-Oil-Pressure-Regulator/productinfo/200%2D1093/
For any that cant pull up the site, here is what it says:
Our new adjustable oil pressure relief valve is a great accessory for your big block Mopar. This unit simply screws in and replaces the original plug which holds in the oil pressure relief plunger and spring. This plug is drilled and tapped in the center with an adjusting screw which can be screwed in or out as desired. The screw is surrounded by a special liquid tight o-ring seal to eliminate leaks, and held in place by a ny-lock nut & ARP washer. Screwing the plug in will put more pressure on the relief spring and raise the oil pressure, while screwing the plug out will release the pressure on the spring, and cause the oil pressure to drop.
