After a fresh oil/filter change I have about 45lbs of pressure using about 5.5-6 qts to fill a 1969 Chrysler small block with 4 bbl. Runs well some valve ticking/noise, not too bad, easy start, no real issues. After about every 3-4 hours of run time the valve train starts to sound louder, the pressure drops to about 25-30 lbs and I need to add about 1/2 a qt and all is fine again. Back to 45-50lbs, valve quiet right down, back in business for another 3-4 hours.
Valvoline 20W-50 is what is in there. Does it with every oil I have used, makes no difference.
So I am fine with this, it is a very old, very high hour engine that I will replace some day. I just need to keep the oil level up and it works fine. The is no oil leaking anywhere, it is just burning off.
The question I have is why such a dramatic difference with just down 1/2 a qt? If it was down 2-3 qts I could understand but just 1/2 qt, I am surprised it starts to act up so much.
It is like night and day, pressure cut in half, lots of noise, so out in the middle of the lake, I idle it down, put her in neutral, add the 1/2 qt while it is running and you can watch to oil pressure rise and hear the ticking subside immediately. Nice but why such a change over 1/2 a qt?
Any thoughts appreciated.
