Thanks Bt Doctur
I agree, though the mechanic says "no chance" or sensor/sender malfunctioning at same time. I am trying to understand other possible root causes before throwing in the towel and having the engine pulled. I don't understand how the oil pump can be the root cause given the symptoms (again, pressure fine until after I run WOT and bring it back down to low RPM - both times exactly the same. Then low pressure at low RPM after. No other symptoms - engine starts/runs fine, temp stable, etc.).
I have had others tell me possible blockage in the "T" fitting that feeds both sensor and sender, possible blockage in oil filter mount, or in other oil ports. Again, how a blockage would result in consistent symptoms described doesn't make sense (but I am not a mechanic).
I will ask the mechanic to check pressure with gauge - only sure way to know.
Any other "quick checks" I can do myself (like change sensor and sender, check for blockage in T fitting, etc.) let me know your thoughts. Appreciate your feedback greatly.
Al
