Oil pressure gauge "nutty"
Mike29
My portside oil pressure gauge is fluctuating from 30 to 45 psi. Hopefully its the sending unit? Any ideas? Could it be the gauge? 1988 454/350 Crusaders 1200 hrs.
Connect a mechanical gauge, and verify...... or simply replace the oil pressure gauge sending unit.
FYI..... a Dual Station boat requires a dual station sender and visa-versa for a single station.
Thanks Rick! Single station. Don't mean to sound dumb but is this Crusader priority or can I purchase this at an auto supply? I have VDO gauges.
The sender units for single station are different for dual stations. If so, an automotive unit should work, but check her with a mechanical gage first.
Jeff
PS: If the readings are accurate, then your oil pump's relief valve is sticking.
