"Hello all I'm new here an
"Hello all I'm new here and I hope that you can help, I can't seem to find any information on the problem that I'm experiencing, and I have serious issues with paying a "honda" mechanic $110.00 an hour to look at my problem and go "duh, never seen that happen". Which is pretty much the response from the two shop's that I have called so far.
Ok here goes. On Saturday I purchased a Mid 80's (red white and blue cowling) BF100, it has the cdi unit and horizontal carb. The unit has been sitting for a year or two, hooked it up to the back of my sailboat, fired on the 3rd pull and idled and ran fine. I took the gas tank down, filled it up with fresh gas and stp gas treatment (not the whole bottle) later that afternoon we took the boat out to watch the sunset. The engine powered us out of the marina (about 15 minutes at 1/2 to 3/4 throttle, and half way across the river then I noticed the green oil light flicker then go out, before I could reach the motor and throttle it down. I was not able to get the engine restarted and we ended up being towed back in. The next day when I took the cowling off I discovered that the small rubber hose coming off of the head, for the water discharge was cracked and had filled the lower part of the engine case? with water, I pulled the motor off of the transom, turned it on it's side and drained it, then I was able to get the engine to start and idle by feathering the choke but no oil light.
I took the motor off of the boat, brought it home, took the oil pressure sending unit off (btw I did check the oil level it was good) and cleaned it, then put it back in. When I started the engine the green light came on at idle then when the engine was rev'd the light flickers and goes out, then the engine dies. I have pulled the wire to the sending unit off and grounded it to the block with the same results so I do not believe that this is anything to do with the actual oil pressure or sending unit.
My questions are has anyone ever seen this? If so how do you fix it? If not I have tried to test the green light, thinking that the water may have caused part of the problem, but it does not light up with 12v, how is the green light activated? Is it some kind of pulsing current? If so how do I test for that.
Thanks in advance for any help you can give."
