Oil level
"As I mentioned before, I have
"As I mentioned before, I have twin 318's, and in the engine manual it reads that the engines were made for a 7 degree angle. My Uniflite came with a 18 degree angle. the book says to just fill oil to full mark on dip stick. With the oil pan off at 7deg. the oil level is 1/2" below rear seal of pan. At 18 deg. at the full mark, the oil is 1 1/2" above rear seal of pan.The front of the alum pan is level at 7 Deg. but is tipped back at 18 deg. that only 2Qts come out and I have to pump out the rest.Is this setup OK???"
"If the oil isn't leaking
"If the oil isn't leaking by the rear seal, swell. What's wrong with sucking the oil out? That's how it's usually done.
JEff"
"I need to replace my upper st
"I need to replace my upper steering control cable. Dose anyone know where I can purchase a MORSE # 560570 33ft OAC1 cable, thanks, john."
